Script to Convert UPPER CASE to Title Case
I see a couple of new script possibilities in scriptmaker but have as yet been unsuccessful in getting any of them to work.
I have about 300 records where I want to change the text from Upper to title case.
TIA
Use the Proper() function.
To replace the contents of a field in the found set, use Records->Replace Field Contents...Calculated result, where the calc is something like Proper(YourField)
Be sure to make a backup of your file before trying a Replace, as there's no Undo.
Many thanks that worked like a charm. Funny that is the first time I have used Replace records with a calc. Usually I use it to populate a field with a value from the first record. This opens up a whole new vista for me.
