Printing with FM Chart Example and Web Viewer
The FM charting example is great... But, I've found that you can't really use the graphs within a report which is kind of a pain. Is there some sort of work around here?
The old preview trick seems to work:
Go to Layout [ “Untitled” ]
Enter Preview Mode
Pause/Resume Script [ Duration (seconds): 4 ]
Copy [  ] [ Select ]
Enter Browse Mode
Go to Layout [ “Layout #2” ]
Paste [ Untitled::aContainer ] [ Select ]
But you need the pause accoding how fast the grap is rendering!
God that would take a while...
Why couldn't they just have added one more variable that stopped it from getting animated -- that's what's causing the issue. The web viewer will normally load the url .. and it does with the charting example, but it stops it as soon as the html doc has loaded which means the flash will never play.
