MoonPhase - Problem Need help pls.
I try to calculate thru Custom function some info about Moon, but result of cf is wrong ... wrong and wrong.
On the Web find some html+javaScript Moon calculator with some but correct result. When I implemented the some formula into my cf result is wrong. Where I do mistake?
Second question is if I use this html+Javascript template how I ken grab the result to filemaker or eventually (easier) to clipboard ??
Will be thankful for help
Ino :Violin::bang: :worship:
MoonPhase_Calculation_Problem.zip
Hi
The CF fails distance and ecliptic longitude
Normally ... The CF fails distance and ecliptic longitude ... i know that, but [color:red]question is: can somebody help to correct CF formulas to get correct result as is in JavaScript.
This is the risen to put also Javascript (web viewer) calc.
Second [color:red]question [color:blue]is it the way to grab or get result of JavaScript from web viewer field to fileMaker directly or thru clipboard ?
Ino :bang:
