connection with Labview - timestamp problems
I have connected Labview 7.1 with FMP8.5 using DataDirect Sequelink 5.4 (ODBC).
The problem is that I cant get a timestamp from Labview to filemaker.
It doesnt even work when i just type "18/04/2007 09:41:32" in a text field in Labview and then copy it to FM. FM always puts it like this
and i have no clue why. Do I have to use a different format in FileMaker or is the problem situated in Labview? Or is it an ODBC problem?
any help is welcome :)
Bart
You might try ISO-time format, and I think DD's driver likes an indicator, try out:
ts'2007-04-18 09:41:31'
to insert into the timestamp field.
thx for your help, i tried the ISO-format and now it works fine. I never tried it before because in my language '18-04-2007' is the standard format
