Need help with fly-out custom menu
Hi, all:
I'm feeling unusually dense today so hopefully you can get my head wrapped around a custom menu problem.
Background:
In the aviation world there's a list we call an ATA list that references different components on an aircraft, like so:
12 Servicing
1210 Fuel Servicing
1220 Oil Servicing
1230 Hydraulic Fluid Servicing
1240 Coolant Servicing
18 Helicopter Vibration
1800 Helicopter Vibration/Noise Analysis
1810 Helicopter Vibration Analysis
1820 Helicopter Noise Analysis
In my solution, rather than send someone off to a layout and have him or her search through all of codes for the one they want (we're talking hundreds, here), I thought, "Hey--why not just have a custom menu named ATA Codes so when a user clicks on it, the main headings appear...
12 Servicing
21 Air Conditioning
...then when a user clicks on the menu item "12 Servicing", a fly-out menu would appear with its subordinate codes, e.g., if I clicked on ATA Codes -> 12 Servicing, a fly-out menu list would appear with...
1210 Fuel Servicing
1220 Oil Servicing
...so if I were to click on 1210 Fuel Servicing, that would populate a text field named (you guessed it) ATA Code.
I've already set up a custom menu for other functions and it's working fine, so... :S
As always, your help will be GREATLY appreciated!
Have a safe and insane Fourth!
This cannot be done with FMP 8.5.
I'd use filtered portals to display the options and allow selection.
Thanks, Vaughan--I was afraid of that.
Currently, I have it set up as a drop-down menu in a portal but because of field width constraints, the text for the longer codes are "ellipsied" out...but filtering the portal is a good idea--something to work on until the fireworks go off later today, anyway. :o
Thanks again!
