Problem with -edit in document() function
Does the "-edit" query command it's job in the xslt document() function.
Are there restriction?
Some additional info:
The same stylesheet gets the recid and modid bij using some other fields. Than the recid and modid are used to update a field called "ActiveSrv".
		select="concat('http://www.gisa.com/fmi/xml/fmresultset.xml?-db=StorageAdvisor&-lay=Servers&-recid=',$RecordID,'&-modid=',$ModID,'&ActiveSrv=',$ActiveSrv,'&-edit')"/>
The URL works fine when past directly into the browser.
Query commands like "-find" work perfect this way.
