First data block is not block 2 ???
Not sure where I should post this. On the FMDiff Differences Report, it shows a Warning saying "First data block is not block 2." Can anyone please tell me what this means? Is this serious? And how do I correct it or what resources should I use to find the answer? Thank you! lpm
I dunno... but try saving a compressed copy of the file and running the report on the new file.
I tried compressing it, but same result. Any other ideas how I can find out what this means? Thanks, lpm
Contact the publishers (Winfried Huslik, iirc) and ask whether the problem is fatal or not.
If it is, rebuild the file or find a backup that's not affected.
