Web Publishing Engine (WPE) crashes a few hours after RegisterGroovy
I've installed the ScriptMaster plug-in for use with FileMakers Web Publishing engine on my FMSA 9.0.3.326/Windows 2003 server
A few hours after running RegisterGroovy under the Web Publishing Engine (WPE), the Web Engine fails and the fmswpc.exe process takes up over 90% CPU. This didn't start happening until I started trying to use the ScriptMaster plugin and RegisterGroovy under WPE.
The "360Works ScriptMaster_WPE.log" shows the plugin loads and functions registered but nothing is added to the log when the failure happens
360Works ScriptMaster_WPE.log:
(C++ Fri Aug 29 14:09:21 2008) Writing to log file at C:Documents and SettingsnambetechMy Documents360Plugin Logs360Works ScriptMaster_WPE.log
(C++ Fri Aug 29 14:09:21 2008)  *** INIT for 360Works ScriptMaster_WPE at Fri Aug 29 14:09:21 2008, headless mode 1
(C++ Fri Aug 29 14:09:21 2008) Found JVM dll at C:Program FilesJavajre1.6.0_07binclientjvm.dll
(C++ Fri Aug 29 14:09:21 2008) No existing JVM found; creating one.
(C++ Fri Aug 29 14:09:21 2008) Enabling headless mode
(C++ Fri Aug 29 14:09:21 2008) 0: -Xms4m
(C++ Fri Aug 29 14:09:21 2008) 1: -Xmx64m
(C++ Fri Aug 29 14:09:21 2008) 2: -Djava.awt.headless=true
(C++ Fri Aug 29 14:09:21 2008) 3: -Djava.util.logging.config.file=C:Templogging.properties
(C++ Fri Aug 29 14:09:21 2008) 4: vfprintf
(C++ Fri Aug 29 14:09:21 2008) 5: -Xbootclasspath/a:C:Program FilesJavajre1.6.0_07libdeploy.jar;C:Program FilesJavajre1.6.0_07libplugin.jar
(C++ Fri Aug 29 14:09:21 2008) 6: -Djava.ext.dirs=C:Program FilesJavajre1.6.0_07libext;C:Program FilesJavajre1.6.0_07lib;C:Program FilesJavajre1.6.0_07libdeploy;C:WINDOWSSunJavalibext;
(C++ Fri Aug 29 14:09:22 2008) JVM started successfully - jvm references is 1838999280
(C++ Fri Aug 29 14:09:22 2008) writeAttachedJarFile(): writing jar C:DOCUME~1NAMBET~1LOCALS~1Temp/360Works_ScriptMaster.jar
Aug 29, 2008 2:09:23 PM com.prosc.fmkit.PluginBridge initLogging
CONFIG: Will write normal log file to C:Documents and SettingsnambetechMy Documents360Plugin Logs360Works ScriptMaster_WPE.log
Aug 29, 2008 2:09:23 PM com.prosc.fmkit.PluginBridge initWindows
CONFIG: Loading dynamic library at C:Program FilesFileMakerFileMaker ServerWeb Publishingpublishing-enginewpcPlugins360Works_ScriptMaster.fmx
CONFIG: Loading plugin jar at C:Documents and SettingsnambetechLocal SettingsTemp360Works_ScriptMaster.jar
Aug 29, 2008 2:09:23 PM com.prosc.fmkit.PluginBridge getPluginClassNameForPluginJar
CONFIG: Loading Plugin class named com.prosc.beanshell.BeanShellPlugin
INFO: 360Works custom SecurityManager has been installed
Aug 29, 2008 2:09:23 PM com.prosc.beanshell.BeanShellPlugin customizeFunction
INFO: Function PluginFunction{name='EvaluateGroovy', functionID=28121, minArgs=null, maxArgs=1} runs in swing
Aug 29, 2008 2:09:23 PM com.prosc.fmkit.PluginBridge scanFunctions
WARNING: Can't do conversions for at least one plugin function
com.prosc.fmkit.types.FMType$UnsupportedTypeConversionException: (-2): No conversion capability for class java.lang.Object
	at com.prosc.fmkit.types.FMType.converterForClass(FMType.java:57)
	at com.prosc.fmkit.StaticFunction.initialize(StaticFunction.java:70)
	at com.prosc.fmkit.StaticFunction.(StaticFunction.java:48)
	at com.prosc.fmkit.PluginBridge.scanFunctions(PluginBridge.java:1065)
	at com.prosc.fmkit.PluginBridge.fmxInit(PluginBridge.java:588)
Aug 29, 2008 2:09:23 PM com.prosc.fmkit.PluginBridge fmxInit
INFO: Creating shared PluginBridge instance / plugin bridge version 1.51
bundlePath: C:Program FilesFileMakerFileMaker ServerWeb Publishingpublishing-enginewpcPlugins360Works_ScriptMaster.fmx;C:Documents and SettingsnambetechLocal SettingsTemp/360Works_ScriptMaster.jar
jvm version: 10.0-b23 from C:Program FilesJavajre1.6.0_07
Operating system info: Windows 2003 5.2 running on x86 architecture
CONFIG: Initialize 360Works ScriptMaster
Aug 29, 2008 2:09:23 PM com.prosc.fmkit.Plugin init
CONFIG: Created new plugin instance: com.prosc.beanshell.BeanShellPlugin named 360Works ScriptMaster; version: 2.03
Aug 29, 2008 2:09:24 PM com.prosc.fmkit.PluginBridge fmxInit
CONFIG: Return VERSION_CURRENT: 51
Aug 29, 2008 2:14:02 PM com.prosc.beanshell.BeanShellPlugin RegisterGroovy
INFO: Registering function 'AuditLog_Revert'
Aug 29, 2008 2:14:10 PM com.prosc.beanshell.BeanShellPlugin RegisterGroovy
INFO: Registering function 'AuditLog_AddDelete( UniqueField )'
Aug 29, 2008 2:14:11 PM com.prosc.beanshell.BeanShellPlugin RegisterGroovy
INFO: Registering function 'AuditLog_AddEdit( UniqueField ; FieldsToExclude )'
Aug 29, 2008 2:14:13 PM com.prosc.beanshell.BeanShellPlugin RegisterGroovy
INFO: Registering function 'AuditLog_AddInit( UniqueField ; FieldsToExclude )'
Aug 29, 2008 2:14:15 PM com.prosc.beanshell.BeanShellPlugin RegisterGroovy
INFO: Registering function 'Select_Attachement_File'
Anyone else seeing a similar issue? Any advice?
I'm going to try running the server with the plugin installed under WPE and not making any RegisterGroovy calls of a day or so. This should tell me if it's an issue with RegisterGroovy or the Plugin itself.
Salvador
WPE just crashed again without any RegisterGroovy calls. Time to try removing the ScriptMaster plugin.
Sal
WPE has been running for 2.5 day with no problems now that I have removed Scriptmaster.
I also noticed the following post regarding WPE crashes on a MAC server:
http://fmforums.com/forum/showtopic.php?tid/195274/
I guess it's time to start looking for an alternative.
Hopefully this plugin becomes more stable down the line.
Salvador
