February 27, 200917 yr Newbies Hello, I'm a complete beginner at this, my inquiry may be completely dumb.. I have a layout that is meant to printed.. it displays data from certain fields.. ie: Hello <>, is it possible to add an additional field input ?, only if there is data in the second field? ie: Dear <> and <>, yet, if no data is in "field 2", then only field 1 is display... without the word "and" as well. I know this might be very easy, but after searching I don't where to start.. Thanks for any help possible.
February 27, 200917 yr Welcome to the Forum. Make a calculated field (Salutation) with the following calculation: Case( Not IsEmpty(LastName);FirstName & " " & LastName &":"; FirstName &":" ) hth
March 2, 200917 yr Author Newbies Wonderful, thanks! I'm not in office to try this but will post results when I do. thanks for a prompt reply. great forum!
