Snow Leopard & FM10 Advanced HELP!!!!
This used to work under 10.5.x, it would list all the local and networked printers when executed as a calculated applescript:
"tell application " & Quote("FileMaker Pro") & ¶ &
"set theDoc to item 1 of (documents whose name starts with " & Quote(Get ( FileName )) & ")" & ¶ &
"set cell "& Quote("LocalPrinterList") & " of current record of layout " & Quote("devOfficeLocations") & " of theDoc to do shell script " & Quote("lpstat -a") & ¶ &
"end tell"
Now I get "A "" can't go after this identifier." Unknown error -2740.
HOWEVER, if I take that script, paste it into FileMaker's Data Viewer it shows me the calculated AppleScript:
tell application "FileMaker Pro"
set theDoc to item 1 of (documents whose name starts with "ION")
set cell "LocalPrinterList" of current record of layout "devOfficeLocations" of theDoc to do shell script "lpstat -a"
end tell
which if run in AppleScript Editor, works fine and pastes the result into my filemaker file.
Any ideas?
