shell script backup will not unzip
Hi All,
Mac OS X..5.8 fms10A
setting up a shell script backup from fms backup to shared directory on same hard drive, as per ConnectingData Wim Decorte method. But the resultant archive will not unzip.
the shell script as below
as a means of testing, running the script in terminal, the archive is created in the correct destination, and is of a size that reflects the contents, but on un-zipping the archive, a progress bar suggests it is unzipping but then at the end, an Archive Utility error message:
Unable to unarchive " "
into "backups"
(Error 1 - Operation not permitted)
Having done the same shell script in terminal on a different mac booted from old clone volume, the result is fine, it unzips, the contents are correct.
Fixing permissions has had no effect
the source directory permissiona are fmsadmin read & write
the archive permissions are user (me) read write; if copied to another mac the zip file will still not unzip
this run in terminal:
#!/bin/bash
# 5 Dec 2005 Rob Russell SumWare Consulting
source="/Library/FileMaker Server/Data/Backups/Daily/"
destination="/Users/Shared/backups/fmbackups"
suffix="$(date +%Y%m%d%H%M%S).zip"
sourcelink="/tmp/sumware001.ln"
ln -s "$source" $sourcelink
destinationlink="/tmp/sumware002.ln"
ln -s "$destination$suffix" $destinationlink
ditto -c -k --rsrc $sourcelink $destinationlink
rm -f $sourcelink
rm -f $destinationlink
generates this result:
Last login: Wed Nov 4 18:07:35 on ttys000
fmsrv:~ cb$ source="/Library/FileMaker Server/Data/Backups/Daily/"
fmsrv:~ cb$ #
fmsrv:~ cb$ destination="/Users/Shared/backups/fmbackups"
fmsrv:~ cb$ #
fmsrv:~ cb$ suffix="$(date +%Y%m%d%H%M%S).zip"
fmsrv:~ cb$ sourcelink="/tmp/sumware001.ln"
fmsrv:~ cb$ ln -s "$source" $sourcelink
fmsrv:~ cb$ destinationlink="/tmp/sumware002.ln"
fmsrv:~ cb$ ln -s "$destination$suffix" $destinationlink
ln: /tmp/sumware002.ln: File exists
fmsrv:~ cb$ ditto -c -k --rsrc $sourcelink $destinationlink
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.1a0n3h: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.bKKeu7: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.YCkjQC: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.gJaek6: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.PVpO9x: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.pAWxOS: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.P9xVjG: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.4WM2bC: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.NwKqjg: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.FNui4P: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.k8GOEd: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.81RPrM: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.54Gvxb: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.C7dT7S: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.rcmK0n: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.jSuwZJ: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.JKufKq: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.9n89OG: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.tt52YW: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.qKGJBh: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.ZTmUu8: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.lb7UQS: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.FY7XdM: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.EGPlKg: No such file or directory
ditto: /var/folders/at/atTm0OGOGnyq0FPCOSZmnk+++TI/-Tmp-//.BC.q4Px5h: No such file or directory
fmsrv:~ cb$ rm -f $sourcelink
fmsrv:~ cb$ rm -f $destinationlink
My first guess is that pkzip or gzip may be corrupt and isn't producing viable archives. System reinstall should do it but if you don't want to waste that time trying to copy those components from a similar machine might be worth a shot.
Hi vladisglad
good guess :)-) (who would of thunk?)
in terminal a simple:
ditto -V -c -k --rsrc ~/Desktop/aaa ~/Desktop/bbb.zip
produced same problem. Looks like an issue in handling the temporary paths.
even this fails:
ditto -c ~/Desktop/aaa ~/Desktop/bbb.zip
so basic CPIO is a problem (-j fails too)
Located ARchive Utility and replaced, but no improvement, so a system re-install I guess (no biggie)
/System/Library/CoreServices/Archive Utility.app
thanks
Chris
