Label Printer problems
Sorry if this is beating a dead horse. I've searched and read a multitude of threads on label and script problems when using a second thermal label printer, but no luck. I can't seem to get my dymo 450 to print directly from FM, it just spits out blanks!
All I really want to know is if there is a way. If so I'll keep trying, otherwise, it's not worth my time and frustration.
I'm running FM 10 Adv on a mac. Is there a solution somewhere? Does one brand / model of label printer work better than another. It seems many users get results from the start, while others, like myself run into these problems. I've yet to find a thread where a no print problem was reported as fixed.
thanks
Revised:
I did get a label today! Different system, but same basic idea. Not completely solved but there's more hope!
  • 1 month later...
This particular label printer is working fine on my windows and airport express system. I didn't ever had a problem with it. I simply created a custom paper on the printer setup and worked fine.
