Read File Contents Help
Hey guys,
I'm trying to use the Read File Contents function to work by looking in a folder besides the tmp folder.
The function works in the example, using the tmp/ScriptMasterExample.txt file but when I try to substitute my own path to a file it won't work. If I place a test file in the tmp folder and have it find it there it works.
When ever I change it something like:
/Macintosh HD/Users/okcpenguin/Desktop/list.txt
I get this error message:
java.io.FileNotFoundException: /Macintosh HD/Users/okcpenguin/Desktop/list.txt (No such file or directory)
Same thing happens if I try to run it in my live file. If I place the file in the tmp folder its perfect, otherwise I get "ERROR"
And I'm staring at the file on my desktop, so I know its there.
Thanks for any help you can provide.
Nevermind...I figured it out.
Left off the "Macintosh HD/" part and it worked perfectly.
