Insert a picture using Frontbase SQL Plug-In
I try to insert a picture into a Microsoft SQL database using the Frontbase SQL Plug-In, but it does not work. The situation is like this:
-Windows Vista Home Premium (SP2)
-FileMaker Pro 10 Advanced (version 10.0v3)
-Frontbase SQL Plug-In (version 1.32)
-SQL Server ODBC driver (version 6.00.6002.180050)
-Microsoft SQL Server 2000 (version 8.00.818)
-Database Name: Test
-Table Name: Files
-Column Name: FileData (Image)
-Picture: C:TempTest.gif
I use External("FBSQL-Connect"; "datasource|username|password|timeout") to connect to the database.
When I try to insert picture Test.gif into table Files through External("FBSQL-ImportBlob"; "INSERT INTO Files(FileData) VALUES(?)|C:TempTest.gif"),
I get the following result: ERROR (0505) [Microsoft][ODBC SQL Server Driver]Invalid precision value.
Can someone help me to solve this?
Thanks!
I just found out that it works perfectly on a MySQL database (with column FileData as data type BLOB).
I don't get it. What am I doing wrong?
