Encodage problem when using EmailSetBodyFile
When using EmailSetBodyFile with an HTML file (charset=windows-1252 or charset=iso-8859-2), all the accented letters are corrupted for the receiver. Example as follow ???
Bonjour,
Groupe H�misph�res vous convie � prendre connaissance des services suivants pour la conservation de vos plans d'eau :)
Have an idea ?
What version of the plugin are you using? Pleas make sure that you are using the most up-to-date version of the plugin, which is v1.944.
I go back editing the HTML with Dreamweaver 4 and ask for an encodage "charset=iso-8859-1" and now everything go well!
By the way, you may note that if you use EmailBodySubstitute Function, you have to add the GetAsCSS(ReplaceString) in order to have international character working.
