xml and asp help
I am having trouble with the simplest beginning to read an xml file from my fmp db.
In the head i have
Dim objxml
'xml initialisation
Set objxml = Server.CreateObject("Microsoft.XMLDOM")
objxml.async = false
objxml.validateOnParse = true
objxml.load("http:.../FMPro?-db=dbname.fp5&-format=-dso_xml&-max=1&-findall")
If objxml.readyState = 4 And objxml.parseError.errorCode = 0 Then
Response.Write "Doc is good"
Else
.. code to desribe the error
End If
This fails with a message "load and parse failed because No data is available for the requested resource". However, the db is not empty.
When I use the url "http:.../FMPro?-db=dbname.fp5&-format=-dso_xml&-max=1&-findall"directly in the Address line of the browser, I get the expected xml file displayed.
What am I doing wrong? crazy.gif" border="0
  • 8 months later...
Did you get it work?
