System settings vs file settings
Every time I open this one database, it asks me if I want to use the system settings or the file settings. It doesn't seem to matter which I choose, the database works properly. But how do I get it to stop asking me to choose when the file is opening?
Save a clone of the file on your system, then import the data from the old file. This will re-set the internal localisation of the database.
Yup, that worked. Thank you!
