Script Parameter / Variable problem!
I’m trying to limit the number of scripts I have by using script variables which are great. I have an issue at the moment though which maybe someone can help me with.
My script parameters are two field names (ie: Table::Fieldname).
These are then defined as variables in a script (ie Set Variable to $$fieldname1 = GetValue ( Get (ScriptParameter); 1).
This part works fine, it sets the script parameter as a variable.
What I then want to do is set another variable from the contents of the field which was defined as a variable from the Script Parameter above. So I set my field contents cariable to;
Set Variable to = GetField ($$fieldname1).
However, all I get now is a ? if I set a blank field to $$fieldname1.
Is what I’m trying to do possible?
It would be great if it was, because I need this script to work for lots of fields and it would be best if they could be defined as parameters. Is there a better way to do this?
Any help would be much appreciated.
Cheers
Sorted it – would have helped if I had put the correct field names into the Script Parameters!!!!
Doh!
