ScriptMaster Advanced Problem
I recently purchased ScriptMaster Advanced version. I was very impressed initially, I've been able to generate the plugin and it works well.
However, I have noticed that if I need to make a change to one of the methods in my plugin, rebuild it and place it in the Extensions folder, all my functions are now in my scripts and I now need to go into each set variable and re-select the method which is really not good.
Has anyone got any ideas on what I should be doing to avoid this problem?
Thank you for reporting this. I've been able to reproduce this issue and we are now working on a fix.
It seems that modifying a module and then rebuilding the plugin is what is causing this issue. Adding new modules does not break existing modules.
