Portal problem
If I want to make the products of related product line appear in the portal in quotation details, how do I do it? If I use the product line number, I know it can be done. However, if i use the product line name, the products would not appear. ...Attached is the file. Many thanks.
KEnt
Product_Info_2010.fp7.zip
I solved the problem. I just check "display value on the second field".
However, I am just wondering whether i can display the productline and the name at the same time in the field.
Kent
