What happens if Java not installed?
I understand all the 360works plug-ins require Java to be installed. I was wondering what happens when you call a plug-in function on a computer where Java is not installed - do you get an error to this effect?
Many thanks,
Steve
If the plugin is installed, but java is not you will get an error when launching filemaker saying that java is required for the plugins to function. With the plugins disabled any calls to a plugin function will return "?" instead of "ERROR" or a regular function result.
