January 31, 201115 yr I have to access a website that updates its data into individual files every day. "EM012811.xml" "EM012911.xml" ... I've got 2 questions. First, the website is password protected. I have the username and password and can download the files, but I can't find a way to use an import function that allows me to pass the username/password to the website from Filemaker. Is there a way to do this? Second, when I download the file "EM012811.xml" to my harddrive, Filemaker is unable to open it as an XML file. "XML/XSL information is not enough to proceed with import/export." If I rename it to *.xls, Filemaker has no problems opening it. Any suggestions? Thank you!
February 1, 201115 yr Author Using wget (http://www.gnu.org/software/wget/manual/wget.html#Startup-File) seems like it should do the trick for part 1. ...if I can figue out how to include parameters with SendEvent. Ugh. I have to access a website that updates its data into individual files every day. "EM012811.xml" "EM012911.xml" ... I've got 2 questions. First, the website is password protected. I have the username and password and can download the files, but I can't find a way to use an import function that allows me to pass the username/password to the website from Filemaker. Is there a way to do this? Second, when I download the file "EM012811.xml" to my harddrive, Filemaker is unable to open it as an XML file. "XML/XSL information is not enough to proceed with import/export." If I rename it to *.xls, Filemaker has no problems opening it. Any suggestions? Thank you!
