Question on custom right-click edit menu
It's been a while since I've worked with custom menus and I can't recall (or find) the way to add the Unformat Text entry to the user's right-click menu in a runtime application. I have it in the Edit Menu on the Top Menu Bar (File ... Edit ... View ... ) and it works. But it would be so much more convenient as a right-click option.
Thanks in advance for any help.
If you always want to remove formatting from text entered in a field, use an auto-enter calculation TextFormatRemove( self ).
In this case, the user needs a convenient way to remove colors and bold words that they may have set. IOW, they highlight a portion of a text field that they want "washed". The Unformat is the perfect solution. It's just in the wrong place.
