Body Part adjusting to size if field
I have a report that could possibly have many lines of information or just one line of information... I don't want to waste the space with the body part being too large and only containing one line of information. Is it possible to have a part adjust itself to match the size of the fields that are in it? crazy.gif" border="0
Under the format menu, select the Sliding/Printing menu item. It allows you to set the selected field to shrink and reduce the size of the enclosing part accordingly.
Thank you - that works... i think I had that already set up, but I just hadn't tested it properly to see if it was really working.... ;-)
Thanks again
you're the greatest!
S.
