Sub Summary Parts won't preview or print
I setup a new layout and I needed subtotals. Everything is in place, Sub summary parts, body, calc fields etc.. When I try to preview the layout or print it. It ignores the Sub Summary parts... Why?
Sub-summary parts only show up when the found set it sorted by the break field. To check what the break field is, double click on the part (the tab at the bottom or to the left of the layout screen) and see what it says. Then sort by that field, and your sub-summary parts should appear.
Chuck
Thanks Chuck. That was it.
You DA MAN!!!
