Problems with IWP not showing the SuperContainer web viewer
Hi... I'm new to SuperContainer and need to upload files via a web browser using IWP.
It should seem to be a simple task but I just can't seem to work it out! Even after reading the included Documentation.html.
From what I understand I need to set the port to 80 in the SuperContainer.jar file for it to work in IWP. I click Options, set the IP:port to 10.0.0.11:80 but it comes back with an error message saying the port is already in use. Specifically:
Problems starting/stopping. Protocol handler initialization failed: java.net.BindException:Address already in use: JVMBind:80
If I leave it as port 8020 it simply shows a grey web view box via the web browser and I can't upload a file.
Any help for a newbie much appreciated.
I knew given time I'd work it out! I just needed to use the external IP reference! Doh!!
Hey,
I am glad you were able to get this worked out! If you have any other issues setting up SuperContainer, paths, etc. I will be happy to help.
