Help with SortValues Custom Function
I am using the SortValues Custom Function which uses another Custom Function MinValue.
http://www.briandunning.com/cf/290 (SortValues)
http://www.briandunning.com/cf/288 (MinValue)
MinValue is causing a duplicate in my SortedValues return set which returns:
Access_Management_Policy_R1.doc
I should be getting back:
Third-Party_Access_Management_Policy_R1.doc
For some reason the MinValue truncates my second filename to match that of the first, which is also the first item in the list of values being processed.
If I use the SortValues with a decending sort (MaxValue), it works fine.
Could someone help me to debug the MinValue function. I have spent considerable time trying to identify the issue and have been unable to track it beyond to the MinValue function.
I appreciate any help that can be provided.
Rob
