Help to create Plugins using c/c++ source code.
Hi all,
I would like to create my own plugin. I am having my c++ coding. I would like to know how to convert that coding as .fmx. I mean which development tool i need to use to create plugin. I have seen plugin is not supported in Filemaker go. Then how to use the plugin feature in Filemaker Go development. If once i created my plugin, Is i need to register that plugin?. Kindly provide step by step instructions to create a simple plugin using c++ code.
Thanks in advance.
