Isdn problem
I use Filemaker 5.0V3
5 PC in network :
A windows NT (with the bases)
2 local PC using windows 98se
2 distant PC using FMP 5 connected via 3 Elsa Lancom 800 isdn routers
I have a problem once the connection is established, the routers does not hang up after time-out expires.
I have very heavy telephone bills (I saw 5003 packets go from server to distant PC preventing routers to quit).
the only (bad frown.gif" border="0 ) solution I found is to quit filemaker after using the base (but the base is big and the connection to server needs 8mn at 64Kb/mn to load)
thank in advance
pierre-henri
