March 21, 201313 yr Hi Folks, I am trying to export some data in xml format from filemaker using XSLT. I want to display the same data in three places on the xml. I was displaying the data once by using for-each tag. <xsl:for-each select="fmp:FMPXMLRESULT/fmp:RESULTSET/fmp:ROW"> <xsl:for-each select="fmp:COL[3]/fmp:DATA"> <marker> <name> <xsl:value-of select="."/> </name> <xsl:variable name="pos" select="position()" /> <comment> <xsl:value-of select="../../fmp:COL[6]/fmp:DATA[$pos]"/> </comment> <in> <xsl:value-of select="../../fmp:COL[4]/fmp:DATA[$pos]"/> </in> <out> <xsl:value-of select="../../fmp:COL[5]/fmp:DATA[$pos]"/> </out> </marker> </xsl:for-each> </xsl:for-each> But when I want to export the above data in three different places in the same XML, It fails. I'm not an XML person so my apologise in the begining if I'm not clear. Thanks very much in advance for your help. <?phpxml version="1.0" encoding="UTF-8" ?> <xsl:stylesheet version="1.0" xmlns:fmp="http://www.filemaker.com/fmpxmlresult" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" exclude-result-prefixes="fmp"> <xsl:output method="xml" indent="yes" /> <xsl:template match="/"> <xmeml version="1"> <sequence id="test_clip"> <name>test_clip</name> <duration>7704</duration> <rate> <ntsc>FALSE</ntsc> <timebase>25</timebase> </rate> <timecode> <rate> <ntsc>FALSE</ntsc> <timebase>25</timebase> </rate> <string>01:00:00:00</string> <frame>90000</frame> <source>source</source> <displayformat>NDF</displayformat> </timecode> <in>-1</in> <out>-1</out> <media> <video> <format> <samplecharacteristics> <width>1024</width> <height>576</height> <anamorphic>FALSE</anamorphic> <pixelaspectratio>Square</pixelaspectratio> <fielddominance>none</fielddominance> <rate> <ntsc>FALSE</ntsc> <timebase>25</timebase> </rate> <colordepth>24</colordepth> <codec> <name>H.264</name> <appspecificdata> <appname>Final Cut Pro</appname> <appmanufacturer>Apple Inc.</appmanufacturer> <appversion>7.0</appversion> <data> <qtcodec> <codecname>H.264</codecname> <codectypename>H.264</codectypename> <codectypecode>avc1</codectypecode> <codecvendorcode>appl</codecvendorcode> <spatialquality>1023</spatialquality> <temporalquality>0</temporalquality> <keyframerate>0</keyframerate> <datarate>0</datarate> </qtcodec> </data> </appspecificdata> </codec> </samplecharacteristics> <appspecificdata> <appname>Final Cut Pro</appname> <appmanufacturer>Apple Inc.</appmanufacturer> <appversion>7.0</appversion> <data> <fcpimageprocessing> <useyuv>TRUE</useyuv> <usesuperwhite>FALSE</usesuperwhite> <rendermode>YUV8BPP</rendermode> </fcpimageprocessing> </data> </appspecificdata> </format> <track> <clipitem id="testclip3 "> <name>testclip3</name> <duration>7501</duration> <rate> <ntsc>FALSE</ntsc> <timebase>25</timebase> </rate> <in>0</in> <out>7501</out> <start>203</start> <end>7704</end> <pixelaspectratio>Square</pixelaspectratio> <enabled>TRUE</enabled> <anamorphic>FALSE</anamorphic> <alphatype>none</alphatype> <masterclipid>testclip3 1</masterclipid> <logginginfo> <good>FALSE</good> </logginginfo> <file id="testclip3 2"> <name>testclip3.mov</name> <pathurl>file://localhost/Users/itsupport/Desktop/testclip3.mov</pathurl> <rate> <timebase>25</timebase> </rate> <duration>7501</duration> <media> <video> <duration>7501</duration> <samplecharacteristics> <width>1024</width> <height>576</height> </samplecharacteristics> </video> <audio> <rate> <timebase>48000</timebase> </rate> <trackcount>2</trackcount> <samplecharacteristics> <depth>16</depth> </samplecharacteristics> </audio> </media> </file> <xsl:for-each select="fmp:FMPXMLRESULT/fmp:RESULTSET/fmp:ROW"> <xsl:for-each select="fmp:COL[3]/fmp:DATA"> <marker> <name> <xsl:value-of select="."/> </name> <xsl:variable name="pos" select="position()" /> <comment> <xsl:value-of select="../../fmp:COL[6]/fmp:DATA[$pos]"/> </comment> <in> <xsl:value-of select="../../fmp:COL[4]/fmp:DATA[$pos]"/> </in> <out> <xsl:value-of select="../../fmp:COL[5]/fmp:DATA[$pos]"/> </out> </marker> </xsl:for-each> </xsl:for-each> <sourcetrack> <mediatype>video</mediatype> </sourcetrack> <link> <linkclipref>testclip3 </linkclipref> <mediatype>video</mediatype> <trackindex>1</trackindex> <clipindex>1</clipindex> </link> <link> <linkclipref>testclip3 3</linkclipref> <mediatype>audio</mediatype> <trackindex>1</trackindex> <clipindex>1</clipindex> <groupindex>1</groupindex> </link> <link> <linkclipref>testclip3 4</linkclipref> <mediatype>audio</mediatype> <trackindex>2</trackindex> <clipindex>1</clipindex> <groupindex>1</groupindex> </link> <fielddominance>none</fielddominance> </clipitem> <enabled>TRUE</enabled> <locked>FALSE</locked> </track> </video> <audio></audio> </media> <ismasterclip>FALSE</ismasterclip> <xsl:for-each select="fmp:FMPXMLRESULT/fmp:RESULTSET/fmp:ROW"> <xsl:for-each select="fmp:COL[3]/fmp:DATA"> <marker> <name> <xsl:value-of select="."/> </name> <xsl:variable name="pos" select="position()" /> <comment> <xsl:value-of select="../../fmp:COL[6]/fmp:DATA[$pos]"/> </comment> <in> <xsl:value-of select="../../fmp:COL[4]/fmp:DATA[$pos]"/> </in> <out> <xsl:value-of select="../../fmp:COL[5]/fmp:DATA[$pos]"/> </out> </marker> </xsl:for-each> </xsl:for-each> <filter> <effect> <name>Distort</name> <effectid>deformation</effectid> <effectcategory>motion</effectcategory> <effecttype>motion</effecttype> <mediatype>video</mediatype> <parameter> <parameterid>aspect</parameterid> <name>Aspect</name> <valuemin>-10000</valuemin> <valuemax>10000</valuemax> <value>33.3333</value> </parameter> </effect> </filter> </sequence> </xmeml> </xsl:template> </xsl:stylesheet>
March 21, 201313 yr I'm EXTREMELY weak in XML ... but what about using a variable? i.e. Set the variable with the field and then use the variable everywhere you want it ?? I way be way off base but it's an idea anyway .......... until someone knowledgeable posts.
March 21, 201313 yr Author I'm EXTREMELY weak in XML ... but what about using a variable? i.e. Set the variable with the field and then use the variable everywhere you want it ?? I way be way off base but it's an idea anyway .......... until someone knowledgeable posts. Thanks Cabinetman for the nice idea but please can you show me how to set a variable on xsl : ) Thanks
March 21, 201313 yr Like I said ... EXTREMELY weak here. A google search will explain much better than I can ........... But something like : <xsl:value-of select="$myvariable"/> .. In place of where the field you want to reuse is. Say like : <xsl:for-each select="fmp:COL[3]/fmp:DATA"> and then add this near the end of your xsl template : <xsl:variable name="myvariable"> <xsl:for-each select="fmp:COL[3]/fmp:DATA"> </xsl:variable> I THINK ... smethng like this may work .......
