JDCBPlugin Oracle Synonyms does not work
I try to access a Oracle database by the JDBC Plugin (using oracle thin jar).
When I use a a table or a view in the same database the sql query it works fine.
If I use a synonym I only get errors back.
Is there a way to access synonyms?
(I tested the sql query with DbVisualizer and the same java jar, the query is correct and works)
Thanks for help
Markus
I have done some more test.
If the table I try to access is a synonym name, I get a onl ERROR back with
jdbcFieldNames ( $table )
and
jdbcGetValue ( $columnName )
Is it a bug?
the query looks like (which works perfect in DBVisualizer)
select sample_name, amount, location, barcode from inventory where sample_name like 'aSampleName';
Markus
