Writing a plug-in using Apple's Project Builder
I am having mucho problems trying to write a plug-in using Apple's Project Builder.
I think the FMFlags.h is wrong: it directs Project Builder to compile a CPU_X86 version, which is not exactly the thing I want.
I am targetting Mac OS X.
All the files provided by FM seem to be set for CodeWarrior.
Does anyone know where I can find a Project Builder compliant version of the FM API files?
Many thanks in advance.
  • 2 weeks later...
Well, I have been told that it is impossible to write a plug-in with Project Builder because FM uses the CFM executable format, while PB only produces mach-o.
So this closes the case.
JPTo
