Solution Wide Popovers
Expanding on a recently released article about Incredibly Easy Menus, which used a Card Window and showcased minimal use of popovers, I've now created a new dedicated setup specifically for use with popovers. Using this method, you can implement the technique and manage your solution-wide popovers from a single location for code. Solution maintenance becomes vastly simplified with this approach.
Remember, our goal as developers is to create DRY (Don't Repeat Yourself) code. This is exactly what this technique achieves. It creates DRY code for the various popovers you'll be using within your solution.
While some degree of context may apply to your popover menus, you can always account for context within the code and adjust as needed. If all the code is in one place, then your job just got easier.
View the full article
