Using GetLiveText()
Becoming familiar with all of FileMaker’s possible technology integrations can take many years. Often, the learning process happens as a side effect of solving a specific need. While you can use almost any other programming language alongside FileMaker, the built-in features can be a breath of fresh air, especially if you haven’t tried them before.
In this video, I take a look at the GetLiveText feature, introduced in version 19.5, which is supported on both macOS and iOS. If you’re using FileMaker Go or working with a large number of images, the GetLiveText functions can prove very useful.
Even if your deployment is primarily on Windows, a single Mac can serve as a processing agent to pick up images and perform some free OCR. If extracting text from images is something you need, be sure to check out this handy feature.
View the full article
