Problem SelectFile MacOS and FMP14 runtime
Hello
I'm having a problem again with a SM module (again because I always have the one with ChooseFolder that appears in the background): I use SelectFile to choose some file; it works perfectly under Windows or MacOS since FMP14Adv But since the standalone solution the dialog box does not appear even under MacOS while under Windows the application crashes. Thank you for your attentionI
Noël
I'm just come back to give a precision :
  1. - I tried to replace SelectFile by ChoosFolder (with the option Files And Directories) and the result is the same :
  • under FileMaker 14 ADV the dialog box appears in background
  • under standalone solution (runtime) it crashes
  1. The crah returns error informations joined under MacOS. Under windows after a moment the application doesn't answer and I don't know if there is an error file created and where !
I tried on my iMac, a virtual // machine and my MacBook Pro for the same comportment !
Hope in your advices
Noël
errorRuntimeSM.rtf
