Nesting Unique field autofill values within if () and case()
Hi guys,
Im trying to autofill a field depending on the value of other fields -- Ideally this field would be autofilled with some text immediately followed by a numeric value that increases by 1 for each new record. I currently have this:
If ( Case1 = "A" ; (Case(Type = "Protein" ; "test1xxx"; Type = "Antibody"; "test2xxx"; Type = "DNA"; "test3xxx")))
I would like to replace the "xxx" components with "000" through "999". I was hoping someone would have some insight on this. Any help would be appreciated.
Thank you!
Create a field and set it to be an auto-entered serial number. Then each part of your calc would like like:
"test1" & theField
Or, like this:
If ( Case1 = "A" ; Case( Type = "Protein" ; "test1"; Type = "Antibody"; "test2"; Type = "DNA"; "test3") & theField )
... but that may not be a good fit if there can be other test types.
Thank you! That worked!
