360Works Products in FileMaker 19
FileMaker 19 is Here!
360Works Products Compatible with FileMaker 19
Claris FileMaker 19 is here, and we are excited for the update! At 360Works, we strive to provide the best possible service and support to our customers and to always keep our products compatible and flexible.
Our plug-ins in each current version available on our online store are compatible with FileMaker 19. We are happy to report that we do not need to release any new versions of our plug-ins listed below, as the current versions will continue to work. Other products we offer have also been tested, and will work with FileMaker 19.
Additionally, we announced our new "Guaranteed Reliability" FileMaker Hosting service this week. We are ready to host your database on the new FileMaker Server 19! Keep in mind, one of the best benefits of hosting with us is that all 360Works products are supported. Plus, MirrorSync and 360Deploy come pre-installed. (*License keys for all products must be bought separately.)
We are delighted with the continued development and innovation of the FileMaker platform and in the FileMaker community. We are proud to be a partner and trusted resource in the FileMaker ecosystem.
360Works Current Products and Versions
Product Name Product Description
360Deploy 2.801 Automated, simple deployment of new database versions
Charts 2.2 Easy-to-use charting for FileMaker
CloudMail 3.3 Send and track email marketing campaigns
Email 3.3 Send and receive text and HTML emails in FileMaker
FTPeek 2.3 FTP upload and download from your FileMaker database
JDBC 2.2 SQL access with JDBC Compatibility
MirrorSync 6.04 Sync FileMaker Go and Pro on a device without network connection, sync FileMaker Servers, and sync FileMaker with SQL databases
Plastic 3.2 Payment processing plug-in
RemoteScripter 2.2 Trigger scripts on FileMaker Pro from the web or IWP
SafetyNet 2.106 FileMaker Server offsite backup
Scribe 4.03 Read and write PDF, Word, and Excel files - plus new OCR functionality
ScriptMaster 5.3 Adds many new functions & create custom plug-ins
SuperContainer 2.9516 A better container field
Web Assistant 2.201 Access internet resources, URLs, and fill out web forms
Web Services Manager 1.72 Publish FileMaker scripts as XML Web Services
Zulu 4.0603 FileMaker calendar sync
Easy Installation
Install plug-ins with ease using the Install Plugin File script step in all environments. For legacy systems, auto-update is supported as well. Find out more at 360works.com/autoupdate.
Best Deal!
If you find a couple of these products to be helpful, check out the 360Works Portfolio Bundle, where you can obtain the entire suite of plug-ins and add-ons with a savings of 75% off of the full price!
Stay updated with 360Works
Twitter Facebook Google+ LinkedIn LinkedIn
