Why won't same info load in multiple places? Why portal won't work ever?
I made an application with four tables: Invoice, InvoiceLineItems,DailyLog, and Contacts.
I would like the application to work as follows:
On a daily basis, I enter info in DailyLog. That info would consist of the company name from Contacts, the date, a description, the hours. Other fields in this table are IDDailyLog auto serial number.
Once a month, I would like to create an invoice for a given contact. I would like to have the company name, contact, address fill based on selection of company. Then I would like to pull in the information for that company for the month via a portal. I would like the portal to display the date, description, hours, rate, total.
I have a PrintInvoice layout that is based on list view that I will email.
I have tried a gazillion ways of doing this. In each case, some parts work while others don't, and I can never get the portal to work. I have done the Filemaker associate and specialist tutorial courses, and recreated everything along with the tutor plus I have worked on another inventory program (traditional product inventory order), so you'd think I'd be able to do this, but no. UGH. I know I don't yet have a good understanding of relationships but I don't think that is all of my problem. Can anyone assist me with this?
Does your invoice include any items other than the hours you have logged in the DailyLog table? If not, then I don't see why you would need the InvoiceLineItems table. All you would need to do at the end of the month is find the DailyLog records in the given month, get a list of unique contacts in the current found set, and create an invoice for each.
It would be a somewhat unorthodox arrangement where the invoice would be related to its "line items" by contact ID and by the month - but then any arrangement where child records are created before the parent is a bit unorthodox.
The invoice would have the rate and the total (hours*rate) and a grand total, plus, obviously the invoice date and invoice number. I need to be able to keep a log daily, and originally I set it up the way you described but it didn't work. Then I thought I could treat the dailylog entries as "products" and pull them in by company and date, or date and company. Maybe my first iteration had some minor issue and I've over-created because I couldn't find it.
I guess I could always redo the whole thing and start with the invoice first (populate the company info, invoice number) and then log the daily info from there.
"Didn't work" is not a useful description of problem. See if the attached demo can get you started.
CreateMonthlyInvoices.fmp12
Oh my gosh, it was so nice of you to send that. Yours works exactly as I wanted, combining the clients with a time frame (the month). I didn't know how to do that! I'm not sure I'll ever know what all was wrong with my portal, even after comparing side-by-side with yours. It's not populating all of the fields of each record, and the record fields it is populating are not populating all in the same row. I will redo with yours and then add the extra fields one at a time. I already added a description field in the portal within your demo and it works fine.
I had definitely put too many duplicate fields on different tables "in case I needed them" and it resulted in a mess.
Thank you for your kind help.
Edited by JudyMom
