Improve FileMaker Script & Calculation Readability with Custom Fonts Using MBS FileMaker Plugin
One of the small but surprisingly impactful usability improvements for FileMaker developers is choosing a better font for scripts and calculations. While FileMaker's default editor font works reasonably well, it can sometimes make it difficult to distinguish between similar-looking characters.
Have you ever spent several minutes hunting down a bug only to discover that a lowercase l was used instead of the number 1? Or perhaps a capital O was mistaken for the number 0? These subtle visual ambiguities can lead to frustrating debugging sessions and wasted development time.
The Problem with Similar Characters
Many programming and scripting fonts are specifically designed to make potentially confusing characters visually distinct. Common examples include:
  • Lowercase l versus number 1
  • Uppercase O versus number 0
  • Uppercase I versus lowercase l
  • Quotation marks versus apostrophes
In large FileMaker solutions containing hundreds or thousands of scripts and calculations, these distinctions can significantly reduce errors and improve readability.
Using MBS FileMaker Plugin to Change Editor Fonts
The MBS FileMaker Plugin includes functionality that allows developers to customize the fonts used within FileMaker's script and calculation editors.
Instead of relying on the default font, you can select a monospaced programming font that clearly differentiates commonly confused characters. Popular choices include:
  • Consolas
  • Cascadia Code
  • JetBrains Mono
  • Fira Code
  • Source Code Pro
  • Menlo (macOS)
Many of these fonts were specifically designed for software developers and provide excellent character distinction.
Example Benefits
Consider the following variable names:
$lOrderID vs $1OrderID
$OCount   vs $0Count
With some fonts, these names can appear nearly identical. With a developer-oriented font, the differences become immediately obvious, helping prevent mistakes during development and code reviews.
Configure the Font with MBS FileMaker Plugin
The MBS FileMaker Plugin provides functions to customize the appearance of various FileMaker development dialogs, including script and calculation editors. Once you pick a new font in the preferences dialog, the selected font can make everyday development work more comfortable and reduce the chance of visual misinterpretation.
Many developers report that after switching to a dedicated coding font, they find scripts easier to read, calculations easier to maintain, and debugging faster overall.
A Small Change with Big Impact
Choosing a better editor font may seem like a minor adjustment, but development productivity is often improved through many small optimizations. Clearer character rendering reduces cognitive load, makes code reviews more effective, and helps avoid subtle mistakes before they become bugs.
If you use the MBS FileMaker Plugin during FileMaker development, consider experimenting with a font that clearly distinguishes similar characters. Your future self—and anyone maintaining your solution—will appreciate the improved readability.
Conclusion
The MBS FileMaker Plugin gives FileMaker developers additional control over their development environment. By selecting a font that clearly differentiates characters such as 0 and O or 1 and l, you can make scripts and calculations easier to read and reduce the likelihood of introducing errors.
Sometimes the simplest improvements deliver the greatest long-term benefits.
