Need Help Again
Here is the scenario
I have a field named "info_Package" and a field named "z_Calc"
I need a calculation that will put a number that i can set in the calculation such as "34" in the "z_Calc" field if the "info_Package" contains a "C"
So if the field "info_Package" contains "ACL" i need a "36" or a "27" (number that i can set in the calc) in the 'z_Calc" field .... however if
"info_Package" contains "AL" need "z_Calc" to have a "0"
Here is the calculation i currently have and it doesn't work
If(info_Package = "C", "1", "0")
Got it ... Thanks to a little help from live oak
here is the code that works
If( PatternCount(info_Package,"A"), "32", "0")
