March 6, 200323 yr Newbies I have a problem ( I believe associated with the MacOS X (10.2.4) upgrade we just completed) with some graphics stored in a global container field. The graphics will not display. I have a calculation field that toggles beween a small graphic in a repeating global container fields based on some If logic that was working fine before the upgrade. It still works on all the PC's just not on the Mac OS X machines. Older Mac OS works. Thanks!
March 11, 200323 yr I has a similar problem. I created a database and did development on both Mac's and PC's. On some layouts I pasted some (.jpg) images I took from the clients web page. This part was on a PC. When the client upgraded from 9 to OSX, the images no longer showed up on the layouts! The OS9 machines showed the images, but the OSX clients did not. My solution at the time, was to go back to the web site, and recopy the images to the layouts using an OSX client. This seemed to work for me. Maybe you need to recreate, or re import the images into the containers. Jerry
