Problem importing fields / related fields
You will need to preform two imports or one import into an auxiliary file and sort out the data destinations by lookup, scripts, etc.
-bd
Greetings Folks
I wish to import an ascii file into FMP5.5. However fields A, b & c into which I wish to import data to, do not show up on the Field Mapping box - they are related fields from another file. Any way round this?
(I do not have a problem generally with importing, just this dilemma.
Many thanks
SEan O'Donoghue
London
