Problem with Filters when Importing Pictures
I'm having problems importing pictures into a container fields. The first time I tried, there was absolutely no trouble. However, after shutting down the DB & re-opening it, FM is no longer able to "see" the pictures on my computer. The "Files of Type" field is defaulted to "All Available", but when you click the drop-down there, the only type available is "*.CGM". I've experimented with this on several different computers & it seems that it does this every time. If you uninstall FM completely & re-install it, it'll work again for one time only.
Am running FM 4.0v3 on Windows XP. Not sure if its caused by an XP conflict or something else. Any suggestions would be appreciated.
I guess even FM 5.5 is not certified for XP. You are 4 versions down, so it may be everything.
