June 10, 200322 yr Hi, I have a report layout on which i want to show several sub-summaries for different fields. For example i have a trailing sub-summary for Gender (3 options) and a sub summary part for Axis 1 disorders (several options). The problem i am having is when i go to preview it is separating the axis 1 and gender options and combining them. E,G, Instead of having: Gender 'Male' Count '2' Gender 'Female' Count '1' Axis 1 'Dementia' Count '1' Axis 1 'Substance abuse' Count '2' It gives me: Gender 'Male' Count '2' Axis 1 'Dementia' Count '1' Axis 1 'Substance Abuse' Count '1' Gender 'Female' Count '1' Axis 1 'Substance Abuse' Count '1' Gender 'Female' Count '1' Why is this and can i prevent this happening? Thanks, Anna
June 10, 200322 yr Maybe they need to be on separate summary reports. A lot depends upon how your data is setup and what you want to achieve.
June 10, 200322 yr Author I have a database full of info on people. I want to be able to produce a report that summarises some of this info on a printable page from a found set of records.. E.g I want to know the number of males and females, the number of people with certain disorders etc. All of this info would be extracted from fields with value lists. Essentially i am trying to produce a report that summarises the selections from specific fields that have value lists attached. I have worked out how to get the selection info from the field but am unable to have it all appear in the order i want on one layout. If i use separate summary reports wouldn't this put each set of info on a separate page?
June 10, 200322 yr you could use the sum() function with relations. or insert the data into globals via script.
