June 13, 200322 yr Newbies Hi, I just know the filemaker for few weeks and I need to make a quick database program for my company. Now I hit a problem. I want to do the function like shopping cart. User search the data in Portal 1 and select the record and record will copy to Portal 2 . I try to use setfield[] , but it only copies the data into first row. I want the data ADD into Portal 2 from Portal 1 instead of just replacing first row. Have anyone has any idea ? Thanks !! Henry
June 13, 200322 yr I think, what you have to do is - when a portal record is selected you create a new record in database that filling up the second portal and then use setfield
June 13, 200322 yr Hi, You're missing a step in the related file involving a global field. Check the sample "Multikey in Action" in the Sample Forum. Apart from Multi-key demo is a "Add to Cart" example.
