Print specific Parts of Report?
Hi People!
Is there a way to specify (after we ran a reports) which Part (header,sub-summary etc.) we want to print. To be more specific I would like to exclude the header (it contains navigational tab-button that I do not care to see printed).
Thank you all!
In layout mode under the format menu, you can select the sliding/printing options for any item on the layout. For any item that you don't want to print, such as buttons etc., check the do not print box. However the blank space in the header part will still appear in the printout. So, the other option is to have a separate print layout that has no header (or a much smaller header) in it. Then, when you want to print, have a script switch to the other layout and print it.
thanx Bob, this sounds like it should do it!
