Another position function problem
I have a global field gEvergentAccountInfoText containing a text block with multiple lines like the following:
account.number: 9999
account.name: Smith Bakers
address.streetNum: 15
address.streetName: Adams
address.streetSuffix: RD
address.city: Fairfield
address.state: IA
address.zipCode: 50219
phoneNumber.npa:
phoneNumber.callingNumber:
I am trying to parse the individual elements using the position function. I am getting confusing results. For example:
Position ( "account.name", gEvergentAccountInfoText , 1, 1) returns 0
Position ( "address.streetNum", gEvergentAccountInfoText , 1, 1) also returns 0
What am I doing wrong?
If you're actually doing what you typed, you have the first 2 arguments reversed. The global field is first, followed by the string you're searching for.
Steve
Works like a charm when you get the syntax correct!
Thanks Steve!
