August 3, 200025 yr Newbies help please. new user, converting large file express 6 database to fmpro5 has trouble with script to 'find' then 'sort' in serial number reverse order (most recent numbers first) works perfectly as seperate scripts but not as a single what am i doing i sort manually on 'unique number' descending open script editor whose lines read: goto layout["data entry screen"] enter find mode [restore, pause] sort [restore, no dialogue] press ok replace find replace sort ok done when i run the script the result is unsorted or sorted in most recent numbers last if you can point me in the right direction, i would be very grateful mal anderson, leeds england (where it is raining very hard at the moment)
August 4, 200025 yr quote: Originally posted by leedtran: help please. new user, converting large file express 6 database to fmpro5 has trouble with script to 'find' then 'sort' in serial number reverse order (most recent numbers first) works perfectly as seperate scripts but not as a single what am i doing i sort manually on 'unique number' descending open script editor whose lines read: goto layout["data entry screen"] enter find mode [restore, pause] sort [restore, no dialogue] press ok replace find replace sort ok done when i run the script the result is unsorted or sorted in most recent numbers last I always seperate my find and sort scripts. I am sure that the script is doing exactly what you told it. I would guess that something in your manual setup procedure has resulted in your saving the incorrect sort format. I would setup the sort script and make sure that it sorts in the order that you want. Then simply add the Perform Script[sort Script] step to the end of your find script. ------------------ =-=-=-=-=-=-=-=-=-=-=-=-= Kurt Knippel Senior Filemaker Developer http://www.database-resources.com mailto:[email protected] =-=-=-=-=-=-=-=-=-=-=-=-=
August 10, 200025 yr Perform the sort just how you want it done. Now open scriptmaker and edit the script, don't change anything just click done, then select the option to update the sort order. Click OK. Now run the script. Hopefully the sort should be OK. If it isn't look to make sure you only have one sort step in there.
