Disconnecting Script problem
I have a database under development (for some time) where I have recently experienced a problem with external scripts failing.
I have a script in database A which calls a script in database B through a perform external script step. When I click a button which runs this script, the database complains that "perform script has been cancelled". When you look at the peform script definition, it seems to know the file but doesn't know which script to run. If you re-establish the correct script, everything is OK until your close the file. Next time you open it, the same error message is back.
I've tried recovering both databases with no effect. Filemaker Tech Support (UK) tell me that this is a scripting problem that I have to sort out myself (so much for subscription support) but I can't see how this is a programmming issue.
Has anyone come across this problem and found a solution for it?
Can you attach a stripped-down copy of your files?
