Help with events and objects...memory
I am creating a script that will select a series of records based on one field, and export selected fields to one text file (delimited) and all fields to another text file...I am just starting with it and am using the "get" method, and am getting memory errors (108), and cannot figure out why...any help???
tell application "FileMaker Pro"
every cell of current record
end tell
also...
cell "Description" as text
every record whose cell "DiscoveryId" = "JEFF FOOTT.00001"
end tell
I'm moving this topic to the AppleScript forum. It should give you a better chance at an answer. -bd
